Airbag car steering wheel problem
  • mmeyer08
    • Sep 2007
    • 163
    So I have a 1990 325is that came with an airbag steering wheel. It is ugly so I wanted to put my m-tech 1 wheel on instead. When attempting to do so it would not bolt down, and had a gap between the back of the wheel and the column. What am I doing wrong? Does that wheel not work in this car? Any help is appreciate.
    fun
    • 37829
    It will bolt right on. You will leave the stock "spacer" behind the wheel that was already there. After you install the wheel you'll need another spacer to go on before the nut so the nut can tighten down correctly. Make sure to remove the white plastic nub that comes out of the column before you put the new wheel on.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
