Carpet Kits
  • GRIZZLY69
    • Jan 2014
    • 83
    Carpet Kits
    Hey so I want to put carpet back into my car but I can't find any kits for 4drs? Will this kit fit into my car?
    Thanks guys
    1984-1987 BMW 325e carpet Heat and Pressure Molded to the original floor pan, made with Top Quality auto carpet materials. Carpet fits BMW 325e 2 Door Coupe just like OEM when installed.
    [‘ᴥ’] GRRR RAWR!!!
  • DesertBMW
    • Aug 2011
    • 1039
    carpet is the same 4 door or 2 door. But that is early model carpet. Later model carpet had foam pad glued to the carpet.
    • GRIZZLY69
      • Jan 2014
      • 83
      thank you so much!!! i have an 85 so early model is perfect.
      [‘ᴥ’] GRRR RAWR!!!
      • AndrewBird
        The Mad Scientist
        • 11898
        ALL years had foam on the backside. That replacement kit won't have foam and won't fit correctly unless you put it over the top of original carpet/foam. Parts of the carpet like the dead pedal are foam behind the carpet, so without the foam, there is no dead pedal.
        • GRIZZLY69
          • Jan 2014
          • 83
          Ok, the car has no interior in it so I'd have to create some sort of foam to fill those areas
          [‘ᴥ’] GRRR RAWR!!!
