Does anyone know how to install the heater control panel? I see theres screwed on the bottom part but I don't see how to get access to them, can anyone give me some guidelines?
Installing heater controls
there are 8 screws...
if you pop out the defroster and hazard buttons, you'll see two small screws going up into the dash...
on the bottom, left and right are screws that go into spring nuts on the lower part of the dash...
you reach them by using a stubby screwdriver on either side of the storage partition in the center console... it's a fidgety job... a magnetic screwdriver (like, a drywall bit) helps a little.
there are four more screws that attach the panel to the heater sliders. if you can't see four holes on the face of the panel between the tracks for the sliders, carefully pry the plastic over off the panel... you'll see them.
