Door lock help!
  • kansas-ix
    • Jan 2004
    • 1600
    Door lock help!
    So my door locks are jammed all the way around except for the drivers door of course, my friends are not diggin the dukes of hazard way of life, I know it is the selenoids and that I need to take all the door panels off and get in there, Any one have extra selenoids? for a 4dr?
    E30 325ix 62k
  • MarkH
    • Jun 2005
    • 65
    Did the power locks stop working on all three doors at the same time? If so, the problem may not be the actuators.
    Check the electrical connector on the drivers door jamb and make sure there is no dirt or corrosion on the contacts. Pull the boot back from the jamb, disconnect the electrical plug underneath it, and thoroughly clean the contacts using an electrical contact cleaner. Dirt in this connector is a common source of door lock problems.
    • kansas-ix
      • Jan 2004
      • 1600
      Pulled passengers door and put in a new actuator and then cleaned all the connections and adjusted everything on the passengers door and blam they all started workin again, door demon exorcised.
      E30 325ix 62k
      • Makster
        • Aug 2007
        • 276
        i'm gonna try this...
