remove upper doorsill trim without breaking it
  • jdt10768
    • Feb 2013
    • 484
    what's the trick to remove the upper part of the doorsill trim - the curved piece of hard plastic trim that covers the weatherstripping for the lower part of the door opening? see image pls
  • jrobie79
    • Mar 2006
    • 2525
    slide it forwards as far as you can, at least past the first clip... use a dowel or something (screwdriver will fuck it up) then pull it up so it doesn't slide back onto that clip and pulli t back till it slides off all the other clips...take the rear seat bottom portion out so you can accomplish this. if it breaks they aren't that expensive new from BMW
    1991 318i ---- 308K - retired
    • The White Guy
      • Jul 2012
      • 144
      Thank you for that information, broke one prior to reading this thread..they are $16.00 each from ECS.
      Now, How do you put them back on? I have two new ones to install with all the new clips.
      Thanks,
      Stan
      • glnr13
        • 1334
        put the clips in the rail/body, line them up with the holes in the trim, pop them in with a hammer fist.
        • The White Guy
          • Jul 2012
          • 144
          Thanks, that's what I was going to do, but I did not order enough clips. I am only 2 short (14 clips total) Maybe I can save some of the old ones while removing all of them. They are a PITA to remove intact.
          Thanks,
          Stan
          • Zesty Bonanza
            • Apr 2011
            • 80
            Does anyone know if the correct clip is part # 51471840961 or is it 51471840960 ? They are different sizes.
            • The White Guy
              • Jul 2012
              • 144
              Yes,
              You need 51471840961for the inner sill. Part number 51471840960 is for the outer door sill.
