I just swapped an older dash into a 1991 318is, and when I got to the point of reinstalling the bolster under the steering column, the swapped dash did not have the same (3) screw attachment points as the original dash - just 3 oval shaped holes with nothing for the screws to attach to. After comparing to the original dash, I noticed that the original did have 3 removable screw in points which I grabbed and attempted to install on the swapped dash. There is no place (metal plate) to install those screw-in points on the swapped dash. Has anyone run into this before? If so, what did you do?
dash swap - knee bolster upper attachment holes
You need the older model parts for this.I just swapped an older dash into a 1991 318is, and when I got to the point of reinstalling the bolster under the steering column, the swapped dash did not have the same (3) screw attachment points as the original dash - just 3 oval shaped holes with nothing for the screws to attach to. After comparing to the original dash, I noticed that the original did have 3 removable screw in points which I grabbed and attempted to install on the swapped dash. There is no place (metal plate) to install those screw-in points on the swapped dash. Has anyone run into this before? If so, what did you do?2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpic -
sigpicComment
yeah instead of that nice vinyl covered lower panel (from the airbag cars), you have to get the cardboard-like lower panel that's held in my half-turn screws instead of actual screws. Also I believe you have to do away w/ that metal support that the lower panel (on the airbag car) sat behind.www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
'15 Mini Countryman - Blazing Red/Carbon Black
Past:
'01 Audi Allroad - Light Silver/Platinum Saber Black
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*Comment
I sure hope there is a way to make the airbag knee bolster and center console work with it otherwise I picked up a clean non airbag dash for nothing.1991 325i - "Scambles" The Daily Driven lightly modded.
1988 Mazda RX-7 TII "Mako" The Free Dorito
bacon by Jared Laabs, on FlickrComment
sigpicComment
I figured. What about the center console though, any way to make it fit correctly?1991 325i - "Scambles" The Daily Driven lightly modded.
sigpicComment
my center console seems to fit fine with the non-airbag dash.
I am just scheming on placing/gluing a metal strip onto the back underside of the dash where those 3 screws attach & drilling out some oval shaped holes, then using the original screw-in clip thingies. Might have to find longer screws, but that's not an issueComment
Have a similar issue. How did you come through your situation? According to REALOEM, there should be no difference in the fastener for the lower left dash panel. However, the fastener (piece 12) while it will work in the dash slots, does not work with the lower dash panel. The fastener does not fit into the round holes.
Any suggestions or pictures that anyone has of the new dash verses old dash attachment area would be appreciated.Comment
