Downloaded the Bentley manual and it wasn't much help. The front windows leak near the very front of the top. There was a screw that could adjust the tilt of the front windows but couldn't find a screw to adjust the height. The window brackets don't use bolts but silicone instead. It's a 92, maybe they changed from bolts to silicone
It looks like the regulator/motor has enough teeth left to seal the gap, but how can I make it relearn? Tried unplugging it while the window was down as well as up but made no difference. I know the PO changed the top with another used one, and the car it came off of had the windows adjusted higher.
