removing carpet today..
  • s52e368
    • 539
    planning on spraying the inside and checking for rust..
    anything i should look out for ?
  • s52e368
    • 539
    yes so i removed teh rear seat and carpet.. low and behold both rear floor pans are rusted out (where the plug is)
    i cut it out and welded new stock in there
    pics tonight ..
    • s52e368
      • 539
      drivers side
      pass side
      drivers patch
      pass patch
      • s52e368
        • 539
        i added seam sealer after the welding and paint with rust protection primer then added a rubberized under coating..
        i also went ahead and removed carpet all the way to the firewall and its clean with no rust (luckily)
        • c0rnfl4k3
          • May 2005
          • 436
          You got lucky there, this is what I get to replace....
          '88 325
          • golde30
            • 11464
            ^ = ouch.
            i better pull up my soaking wet carpet and see what kinda suprises i have in-store for myself...
            IG: @Baye30
            • AndrewBird
              The Mad Scientist
              • 11892
              So wait, you patched OVER the rusted out spots? Be prepared fro more rust later. You need to cut it out to stop it. That's why its nickname is cancer.
              Also, isn't there just a plug of metal that fills that hole?
              • s52e368
                • 539
                i did cut it out ...
                as stated in post number 2
                • Kip
                  • Feb 2006
                  • 183
                  Best Mod Ever!!!
                  Originally posted by s52e368
                  drivers side
                  TERRARIUM MOD FTW!!!!11!!!!!11!!!!!!!!!!!!!!!
                  88 325is FOR SALE
                  89 325i FOR SALE
                  95 LR Disco
                  98 Volvo V70XC -FS!
                  25' of oil-stained driveway
                  Travel Kit:
                  M4, FS 92, Mk19, 998
