I must say it was heavvvvy, but after taking it all off i could say it got about 60 lbs lighter, me and my friend did it to our cars and it work out great. There are two layers the top one peels off semi-easy and the bottom layer is the b****, i just park it under the sun with my trunk open and we took it off. You will be amazed how heavy it is if u do this.
Trunk Tar Removal
Tags: None
the trunk isn't the only place, its ALL throughout the interior, the tar on the inteiror is not as thick but it would all still probably add up to 20lbs most probably. just a suggestion.Comment
go to your trunk left the carpet up and you will see it all over and around the spare tire, take the carpet out and start peeling it off, if you want to make it easy on ur self park it under the sun and let it warm up a bit before you tackle itComment
I took mine off and weighed it. ~47 lbs.Originally posted by S50fanatic1985but after taking it all off i could say it got about 60 lbs lighterComment
u won't even notice the sound difference. Although i've read that it was for sound deadening as well as weight balance, i don't think it has much to do with sound deadening, especially counting that the 318 didn't have it. I weighed mine when I removed it all, I had it at ~53lbs.
:(^SOLD^:(Comment
