anyone used mtech 2 wheel...
  • bmws50b30
    • Aug 2005
    • 1151
    on an airbag car? i replaced my airbag wheel with an mtech 2 wheel but it's not turning all the way and it's constantly hitting the turn signal return. i then just replaced it with a momo wheel. no problems at all.
    does this mean you can't use an mtech 2 wheel on an airbag car?
    1991 330is
  • Teaguer
    • Sep 2004
    • 6167
    You gots to use a spacer/washer mang .
    • bmws50b30
      • Aug 2005
      • 1151
      i did used a spacer in between the wheel and the nut but not behind the wheel. that's why the momo adapter worked with no wiggling of the wheel. would it make a difference if i put a washer behind the wheel?
      1991 330is
