If you have a 'vert or seats that came from a 'vert you have probably figured out that the seats don't recline much at all. This "feature" is designed to prevent you from reclining the seats back into the rear side panels, but the engineers went a little crazy with how limited they made the recline stop.
If you want to get rid of this "feature" and just be careful when you recline your seats, it is an easy task. Follow along kids!
Remove seats from car. Remove the plasic covers on both sides that cover the seats mechanicals.
See the black plastic "button" that is under the knife? Cut it off.
Once you have most of the material cut off, use a large drill bit to drill through the rest. It is okay if you take a little of the metal braket with you - you just need to make sure all the plastic is removed so you can easily pull the spacer out.
Use a screwdriver and or pliers and pull the spacer out - it may be stubborn. Here is what the spacer looks like removed.
Repeat on the other side. Before putting the covers back on, try reclining the seats to make sure they work. They may be stiff and/or won't hold the recline position. Try oiling the mechanism at the two places shown by arrows in the picture below. Be careful doing this, you don't want oil on your seats! Make sure to apply the oil to the inside of the mechanism - the parts that need oiled are sandwiched between two out metal brackets. This loosened up my seats quite a bit.
Put the covers back on and then put your seats back in the car. Go out at night, put the top down, recline the seats and enjoy kicking back and staring up at the stars.
