E30 dash removal/installation
  • ramulus
    • Apr 2018
    • 12
    I posted this in the DIY section and realized that was probably a mistake. But, I was wondering if anyone in these forums lives in the NOVA area and has the experience to remove and install a new dash. I feel like I would be overwhelmed if I tried it myself and I really don't want to take it to a shop.
    Any takers!?
  • fresh_TD
    • Aug 2013
    • 2457
    Where are you located? I'm in Alexandria
    Sent from my Pixel XL using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • ramulus
      • Apr 2018
      • 12
      I'm super close. In Springfield. Right off Rolling rd and Old Keene Mill.
      • Court M3
        • Jan 2004
        • 6713
        Tackle it, patience is key but it can be done! There was a tutorial on here at one point and printed it out and did it that way.
        Continuous For Sale Thread
        323i s50
        • jdt10768
          • Feb 2013
          • 484
          yeah, you can do it - take pics as you go, put hardware in zip lock baggies and label with step # etc. Took me a couple days going slowly, using the detailed diy pictorial. Then a friend of mine did his in 2 hours, hahaha
          • Mike36
            • 1079
            Step-by-step BMW E30 dash swap guide: full removal and installation of the dashboard, with photos and tips for a clean, rattle-free result.
            Take pics as you remove and unplug items. Tag wires with tape an organize screws with the parts that you removed them from. Don't forget to swap VINs and take your time.
            Also compare your dashes after you remove your old one. Apparently non airbag and airbag cars have different mounts on the edges, at least mine did. I had to dremel my new dashes mounts to match my old dash.
            • fresh_TD
              • Aug 2013
              • 2457
              Went over ramulus place, removed and installed new dash in about 3hrs.
              • HCMW Adam
                • Oct 2016
                • 209
                Originally posted by Mike36
                http://www.rtsauto.com/45/
                Thanks for the link. I am going to need that info soon.
                • blue30vert
                  • Sep 2018
                  • 6
                  I’m 15 years old and my e30 is the first and only car i’ve ever worked on. I did it myself and it really wasn’t hard at all, just tedious. The only thing i needed help with was putting the new dash in, you have to angle it perfectly to get it to go over the steering column. Good luck!
