Analog clock
    • 37832
    Analog clock
    This was probably covered once before but if you have an analog clock in your E30, please post pics and thoughts, thanks a lot.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • kencopperwheat
    King of Kegstands
    • 14396
    I got mine on eBay, shipped from AUS. It's a DIRECT swap IF you have the old-school BASIC digital clock.
    Originally posted by Gruelius
    • bwanac
      • 3354
      If you dont have the old skool 2-button clock you will need to do some fancy wiring or...
      Buy a wiring harness from a 318 that had the 2-button clock. I got one around, I just need to go to the junkyard to pick up the wiring needed!
      They are def an improvment in the interior!
      • LikeCDoos
        • Jan 2004
        • 2522
        Ken what is that box in the middle of your dash?? It looks to be a seatbelt sensor light or something. I've never seen that before.
        • kencopperwheat
          King of Kegstands
          • 14396
          Only on the early 318. It's a seatbelt light and a light goes off when you need to change your O2 sensor (but it's only designed to go off once, and then you have to remove the bulb).
