Door Card Question
  • MuDuRkKiO
    • Aug 2018
    • 48
    Door Card Question
    Is there any good way to convert rear door cards, from a sedan/touring, that are hand operated to ones with the switch? In my case, I have found a set of door cards but they have the hand crank. And whilst I can 3D print a cap to cover the holes in the front pair, my issue is that the rear pair wouldn't have anywhere for the switches to go. I assume I would have to just cut a hole but am unable to find a good writeup on how exactly to do that. Or am I better off just trying to find ones that are from a car with powered windows?
    Sent from my LG-H932 using Tapatalk
  • roguetoaster
    Biggus Tippus
    • 7830
    To delete the cranks there is an OE part that goes in the hole, you can find them on early car part diagrams.
    Yes, just cut a slot for the switch. Some, but not nearly all, door cards have perforations or marks on the back side for switches.
