How hard to install map light rear view mirror
  • clydesdale
    • 631
    I have an 87is. It has the overhead check engine indicators and an electric moonroof. I guess I can tap power off of one of these two systems. Anybody already done this?
  • JRowe
    • 352
    It's pretty easy. I did it when I converted to a power sunroof. I used the factory wire that runs down the A pillar to under the dash. I was running power for the sunroof anyway so it just made sense. I shouldn't be a problem to power it up off the hot lead to the sunroof.
    • StereoInstaller1
      GAS
      • 22679
      Nope. Not possible. Don't even try it, your car might explode.
      I will help you out though...you can send me that mirror.
      Seriously...run the wires over to your domelight and connect there.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • E30 Cabrio
        • Oct 2006
        • 1954
        1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
        Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
        Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
        • clydesdale
          • 631
          thanks, that was what I was looking for.
          • Mr.SWISS
            • Nov 2005
            • 1251
            Luke
            That's what I did, wired to the constant on the pass dome and voila. It is alot easier when you have the headliner out BTW.
            Originally posted by 325Projectz
            don't listen to the diagram... listen to mr. swiss.
            :nice:
              • 37833
              In my old E30 I spliced the maplight in to switched power from the check panel. Worked just fine.
              Grover Beach, California
              BimmerHeads.com
              • rede30
                • 4697
                I did this too but if you use the dome lights then you can use the map light when the car is off.
                  • 37833
                  I figured it was better to have it switched so it wasn't left on on accident.
                  BimmerHeads.com
                  • erik325i
                    • Jan 2005
                    • 3567
                    If you want to be able to use them whent he car is off, you can wire them up to the constant power at the check panel instead of the switched power. There's really no need to run a wire all the way to the dome light.
                    -Erik
                    • Van Westervelt
                      • 9365
                      ANyone have any experience playing with the switch to make them switchable on/off as well as on with the domes when the doors open? I am going to do it, just curious if ayone has yet, save me some work and brain calories :)
                      • ivo316
                        • Oct 2006
                        • 1222
                        Hey great site !!! http://e30.bmwdiy.info/index.html
                        Thanks for that info :)
