Cannot remove Momo Hub
  • gerlando
    • Sep 2006
    • 43
    I tried to swap out a Momo wheel with an M-Tech tonight and ran into a bit of a problem. I got the 6 hex screws and the 22mm hub nut off no problem but the hub adapter would not budge. I tried prying it off the steering column a bit but was afraid of breaking something. Is it supposed to be this difficult?
    My next option is to pick up a 3 arm puller and try that.
  • backtrail69
    • Jul 2005
    • 4471
    Get a steering wheel puller.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
      • 37833
      Did you have the key turned on so that the steering wheel lock disengaged?
      Grover Beach, California
      BimmerHeads.com
      • blueapplesoda
        • Dec 2005
        • 1904
        yes, do check that. steering wheel will not come off without the key turned.
        • backtrail69
          • Jul 2005
          • 4471
          Yea...I guess that would be obvious..
          :: PNW Crew ::
          • gerlando
            • Sep 2006
            • 43
            Sorry I don't think I was completely clear in my first post. I'm trying to remove the momo hub adapter to install the M-tech. I've got the hex nut off and removed the spacer. I can see the splines from the steering column but the hub won't budge. I guess I just didn't expect the hub to be on that hard since most everything I've seen online says it's a quick swap. It feels like this thing must have been pressed on the column really hard.
            Oh,.. and I tried removing the hub with the column locked and unlocked with no difference. Anyway,.. I'm off to get a puller,... thanks for the advice!
            • PeaveyBassist
              • Sep 2004
              • 3511
              Check all the splines on the column when you get it off. A couple flattened splines will make it a beyotch to get it off.
              Will
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • 37833
                Well FYI it must be unlocked. It's the same theory as removing a regular E30 steering wheel.
                BimmerHeads.com
