Dyeing Panels This Weekend – Pointers?
  • Dex.e30
    • Mar 2007
    • 153
    • front door panels
    • arm rests
    • rear seat side panels
    • rear deck
    Plan is to vacuum thoroughly, wipe off with mild cleaner and paper towels, and finally shoot several light coats with the VHT Satin Black.
    Any BTDT tips?
    >>> My E30 For Sale <<< ||| My MCoupe For Sale ||| Miscellaneous Items FS ||| *E30* Items FS |||
  • amdspitfire
    • Mar 2006
    • 254
    Originally posted by Dex.e30
    • front door panels
    • arm rests
    • rear deck
    Any BTDT tips?
    take pics for us!
    • backtrail69
      • Jul 2005
      • 4471
      Follow the directions on the can. Might wanna scuff up the vinyl/plastic a little if you can to help adhesion.
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • td325ic
        • Feb 2006
        • 786
        You pretty much got the idea. Here's what I'd suggest just to add to it.
        1) Remove all panels from car. Disassemble parts.
        2) Vacuum all debris and gunk out of cracks
        3) Wipe down thoroughly with either a Wax/Grease Remover (PPG DX330), or 99% Isopropyl Alcohol, or clean with blue Dawn dishwashing soap.
        4) Scuff lightly with a 3M red scouring pad ("scotch-brite")
        5) Wipe down again with cleaner
        6) Mask anything with blue painters tape you don't want overspray to get on. Setup a clean area to paint.
        7) Use a tack cloth (Surgical Blue preferably) and with a light touch remove any surface dust.
        8 ) Do one or two light coats of an adhesion promoter (such as Bulldog adhesion promoter usually available at Pepboys) Give around 4 or 5 min between each coat. Wait 10min before next step.
        9) Spray 3 or 4 light coats of a vinyl dye. I prefer SEM products such as their Classic Coat and Color Coat. Give about 5min between 1st and 2nd coat. 10min between 2nd and 3rd, and 10 - 15min between 3rd and 4th
        You may also want to try SEM's Vinyl Prep as your cleaner.
        If all else fails, I do have a nice condition coupe black interior panels and dark grey rear shelf for sale ;)
        • Majikal
          • 518
          I wouldnt scuff up the panels if I were you... I painted mine in the last couple of days, if u scuff up the pieces, the vinyl paint will NOT cover that up. It adheres just fine if u clean it right with degreaser, or actually water with a drop of dish soap works well too. If u get any light scratches in it by scuffing it up, ull need to primer it to cover that up, therefore losing the texture. Take a look at my pics a few posts down and see results without scuffing it up!
