they are great! I have one in my e30, it uses the rear factory mounting locations and then bolts to the drivers seat for the lap belt. Toss it on the floor behind you when your done and use the 3pt for daily driving. Cheers Brian
I have a set of 4 points in mine too. Bolts up to the seatbelt bolt on the inner side of the seat, then either the floor or outer side of your seat (dependant on if you have a 2 or 4 door), and the rear bolts into where the rear seat belts bolt in down low.
If your shoulders are more than 2 inches above your seatback, you shouldnt use this type of harness setup. Go with a harness bar, or a full roll bar with a harness bar integrated.
