Sunroof Problems
  • atomic
    • Jun 2007
    • 5691
    Sunroof Problems
    I have a probem with my sunroof. It is an electric sunroof. It will pop up and back down with no probem. And when you go to slide it back it will move about an inch and then stop. You can hear the motor still wanting to run with finger on switch. And then it will close with somewhat of a out of sync. What do you guys suppose is the problem here ? Trying to open it manually does not change anything at all as well. With the manual crank in place it operates the exact same as the power switch operation sooo.... any ideas would be very helpful.... Thanks
