Central Locking Retro
  • Maeda
    • 210
    When I rewired my whole chassis, I stupidly gutted everything and tossed EVERYTHING! Meaning that my central locking system is gone.
    What do I need to get this working again? Is there some kind of 'brain' to the system that i'll need? I can't quite seem to decipher the realoem picture. :\
    Everything IN the door is still there, so i'm guess thats the actuators, and such.
    Could I just wire an alarm to the actuators and call it a day?
  • Maeda
    • 210
    I found the brain unit thing...... i guess i just have to rewire the doors together and give power to the unit?
    • StereoInstaller1
      GAS
      • 22679
      in a word, yes.
      Closing SOON!
      Thanks for 10 years of fun!
      • Maeda
        • 210
        in a word, yes.
        If you were going to give me the long version what would it be?
        • StereoInstaller1
          GAS
          • 22679
          Basically, it would depend on what alarm you did.
          Most these days do not have onboard relays, so you would need to use 2 relays to run the actuators...the alarm would run the relays.
          If it happens, I would be glad to help on wiring diagrams.
          Luke
          Closing SOON!
          • AndrewBird
            The Mad Scientist
            • 11898
            My question is, why did you rewire your car in the first place?
            • Maeda
              • 210
              It was much easier to do this with my own chassis wiring.
              Stock bmw wiring is garbage. It's so old and corroded and badly run, and insulated. I went with a much simpler, much easier to trouble shoot, and much better wiring. I got to thin the thing down to about 9 circuits, and only kept what I wanted. Unfortunately I mistakenly ditched power locks without thinking. Plus you get to rerun all the wires where you want, and how you want.
              I redid everything with expanding sleeve, heatshrink, and beefier wire for the essentials like headlights, alternator, and battery. Now I have a TINY harness that still has all the functions I need to run the car, as well as a couple other things that add some comfort like power windows, sunroof, and radio.
              Stereoinstaller: I did more poking around and I dismounted the door lock unit, and relays, but found them bouncing around behind the kick panel. It looks like i just need to extend the wiring back to where it was, and through my new fusebox.
              • e30edward
                • 777
                i was wondering if u could just get rid of the central locking all together and just maually lock everything. would this be possible?
                • e30edward
                  • 777
                  i was wondering if u could get rid of the central locking all together and manually lock everything. would this be possible?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    You mean, lock each door individually? I don't see why you couldn't.
                    As far as the rewire, nice job. I had hoped you weren't just some idiot who decided to "rewire" his car for no reason. I.E. - Hack it to pieces then say nothing works and ask how to fix it. ;)
                    • golde30
                      • 11464
                      im going to be running all 4 actuators off a Clifford alarm soon. my installer said the same thing as Luke, hes gonna install 2 relays, 1 for the front doors, and 1 for the trunk and fuel door. there is a short in the wiring to my central locking unit, so this was in my opinion the best solution.
                      IG: @Baye30
                      • Maeda
                        • 210
                        Originally posted by NitroRustlerDriver
                        You mean, lock each door individually? I I.E. - Hack it to pieces then say nothing works and ask how to fix it. ;)
                        On the contrary! Everything works except the locks, sunroof and the dome lights. I haven't gotten around the the last two, as they aren't all that important to me.
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          Did you document any of the rewire?
                          My 2.9L Build!
                          • Maeda
                            • 210
                            No. It's really easy, I didn't see a point.
                            The wires came prelabeled, and the fuse box prewired. All you have to do is run the wires, cut what you don't need, and connect to your old plugs.
                            • Maeda
                              • 210
                              Behind my driver side speaker I found small harness with
                              Red/Black - 12v?
                              Brown - Ground?
                              Green/Purple - Lock?
                              Green/Black - Unlock?
                              Ok staring at this wiring diagram has me baffled. I admit defeat! I need some help.
