After putting in my mtech2 wheel, the blinkers don't reset
Check the pawl on the turn signal switch itself. With the wheel off, when you engage the turn signal either left or right, a small plastic pawl should stick out, which will cancel the turn signal as the wheel turns and the little 'arm' on the back of the wheel sweeps across it.
If the previous owner did not ensure that the turn signal was in the center/neutral position when he put the wheel on, he may have snapped it off.
Voice of experience... :(
John in MD - 1991 318is 190k miles and still rolling!
