Will Cobra misanos fit in an E30? they have a 540mm wide bottom part as seen in the pic. will it rub on the door pockets or the centr consol?
Thanks in advance..
540mm ~= 21.25". I think I measured 22.5" across when fitting my recaro sport, so you should be okay in that respect. However, the bolsters angle out as they come up from that bottom measurement so clearance is reduced a bit.
