Speedometer
  • Jimbo
    • Apr 2007
    • 92
    Speedometer
    Sometimes lately the e30's speedometer will just not work and other times it will. Obviously like some other e30's my odometer doesnt work, but come on gimme a break atleast lemme know how fast im going. Can anyone help with this problem?
  • Tavern Gnome
    • 2137
    mine does the same. from what I've read it could be the sensor on the diff. Just unplug it and clean it up. Could also be the solder points on the back of the speedo need to be reflowed IIRC. Good luck.
    __________________
    1987 Toyota Landcruiser V8
    • maxel
      • Jun 2007
      • 116
      its probarly the sensor, clean it and if it doesnt work change it
      Axel
      BMW 320i Touring (M20B25)
      • jw 325ic
        • Sep 2006
        • 1360
        could be sensor, speedo, or even SI board. any problems with other gauges? well if you have a 13 button obc, just hit the avg mpg and reset lol, itll show ya.
        • Jimbo
          • Apr 2007
          • 92
          hehe dont have to wrry about it now, got in a wreck and yea lol. But thanks guys for trying to help out, If it happens on my next e30 Ill definitely try the ideas.
          • einstein57
            • Jun 2007
            • 10780
            i had that problem with my tach. It was a fried circuit panel. cooked the wire right off the board.
            www.gecoils.com
            • Jimbo
              • Apr 2007
              • 92
              dayum
              • rmousir
                • Nov 2007
                • 147
                I had this problem.. Turns out the solder on the circut board for the speedo over time lets the connection on the board losen up. Believe it or not I resoldered the connections and now it works like a champ. If you ever need a write up on what I did I have one. I got the idea from another site on the net.
                Cheers.
                rmousir
                '87is work beater
                the RED BARON!
                RUNNING GREAT!
                After a $10.99 Intake Manifold Gasket.
                • Ray McCooney
                  • Jun 2006
                  • 1088
                  Cheers.
                  +1 for what this guy is talking about. I performed the same exact procedure, of which alleviated my fluctuating speedo issues. Your odometer not working is 99 percent likely to be a broken gear(s). Good luck.
                  • rmousir
                    • Nov 2007
                    • 147
                    bad part is the cheapest place I have found for the gears is
                    Replacement automotive gears for odometers and speedometers
                    still $60..
                    bummer. anyone know where to get them cheaper?
                    Richard.
                    rmousir
                    '87is work beater
                    the RED BARON!
                    RUNNING GREAT!
                    • einstein57
                      • Jun 2007
                      • 10780
                      you can buy them individually if you only need the small one. i bought mine from bav auto for $25. It came in a box big enough to hold a melon.
                      www.gecoils.com
