power windows no workie?
  • aaron325ix
    • Jun 2007
    • 1489
    I just got my interior back in, and retro fitted heated seat wiring. After it was all back together the windows dont work, or even light up for that matter. Havent had a chance to really explore yet ( got dark and i was hungry) but I think everything was plugged back in correctly. Heated seat switches appear to work. Fuse 17 is in tact. Any ideas? Thanks.
    AW
    EDIT: I am aware of the breaker
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    curcuit breaker tripped?
    • aaron325ix
      • Jun 2007
      • 1489
      That was the first thing I checked, it's good. Still no power
      • LINUS
        • 2422
        power to the breaker?
        also, swap fuses with a known good one - I know, but sometimes a fuse you swear looks good isn't. Fuse quality has gone to crap in the last 5 years it seems.
        It's not how you handle the good times, but the faith you keep in the bad that defines you.
        • aaron325ix
          • Jun 2007
          • 1489
          OK so half of my breaker was unplugged. I guess i didnt notice cause it was dark last night. I'll take the dumbass award of the day.
          • marksv4
            • Mar 2006
            • 174
            Where is the breaker for the power windows?
            Thanks guys, mine are not working either.
            91 E30 318is DS/Anthrazit S14 & 5 bolt
            99 E36 M3 Cosmos/black leather
            06 E90 330i Black Sapphire/black vinyl stuff
            WTB: Black 71-76 2002
            www.bcbimmers.com
            • BBY1104
              Check the "big black relay" in the fuse box. Had a friends quit working and that was the problem
              • redhatpat
                • Aug 2005
                • 656
                The wiper relay? I'd like to hear how that kept the car from running.
                • brandondan1
                  • 1091
                  Since you have a 91, it's probably located above the passenger side window switch. First make sure it's not pressed down, and if not, take the switch out to see if both leads are connected (correctly).
                  91 318is
                  • BBY1104
                    I thought that was for wipers and windows. Hmmm guess not there should be a relay in the fuse box for the windows.
                    • brandondan1
                      • 1091
                      Power windows and sunroof should be on fuse #17. 30Amp.
                      No relay for them though. http://e30m3performance.com/maintena...e_box/pg-2.gif
                      91 318is
