Those interior lights in the headliner
  • dinanm3atl
    • Feb 2007
    • 7305
    Both mine don't work. I have 2 new ones. They "mounts" seem to have broken.
    How do I fix this?
  • Court M3
    • Jan 2004
    • 6713
    Did they both go out at the same time? if not, maybe the the door switches?
    Continuous For Sale Thread
    323i s50
    • dinanm3atl
      • Feb 2007
      • 7305
      No I turned the 2nd off. The housing is definitely broken on the driver side.
      My problem is I think the mount is broken. They both are just held up by the headliner. How do I "mount" them?
      • ak96ss
        • Nov 2005
        • 461
        Did you get an answer to this? There is a plastic plate that serves as the mount for the headliner lights, you should be able to just peel back the headliner and replace this plate, then reglue the headliner in position.
        Not the best picture of it, but you can see the mount here:
        John in MD - 1991 318is
        190k miles and still rolling!
        • Jand3rson
          • 37587
          Replace the bulbs in the lights with LED's. Over the winter, I'm going to replace pretty much every bulb in the car that isn't a headlight or taillight with an LED.
          • dinanm3atl
            • Feb 2007
            • 7305
            cheap plastic holders? Damnit mine are obviously broken :(
            How do I replace them? Drop the headliner? Lucky me... Can you explain more about peel back the headliner?
            • ak96ss
              • Nov 2005
              • 461
              The headliner is glued in place, underneath the door seal among other places. You'll have to pull the door seal off, then peel the headliner back to get to those plastic plates that hold the lights in place. Then, a shot of 3M Super Adhesive or the equivalent trim glue, and put the headliner back.
              • dinanm3atl
                • Feb 2007
                • 7305
                I'll give it a shot. Now to try and find those stupid things in real oem
                • ///M42 sport
                  • 3952
                  are these gonna be brighter? I checked out superbrightleds.com but was kinda skeptical about the lumen output you can gain. I'll look forward to your results.
                  • dinanm3atl
                    • Feb 2007
                    • 7305
                    I just want to fix :)
                    • mopower
                      • Apr 2007
                      • 24
                      I'm in the same boat, my passenger side light is hangin by the headliner. Where the hell can you get these plastic holders?
                      • Jordan325iC
                        • Aug 2005
                        • 1697
                        Mine are both also screwed. Probably going to hit up a junkyard for these.
                        Slightly OT, but my drivers' side switch doesn't trip the lights. I replaced the switch and still no light. Where else could the problem be?
                        '88 325is
                        VP UT of Austin Autoholics
                        BMWCCA 380364
                        • soviet1942
                          • 237
                          Where can I get these and how do they look?
                          • Schneider325
                            • May 2004
                            • 3818
                            bavauto.com, anyone who sells LED's.
                            They look like bright lights.
                            • DaveSmed
                              • Apr 2007
                              • 1407
                              Central locking work?
                              -Dave
                              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                              Need some help figuring out the ETM?
