pull that thing off, and put a couple layers of fiberglass on the inside, and sand all that bondo down till smoth, then if you have any goudges or anything go back to NAPA and get some glazing putty. Thats what it is called here...it is a thinner last coat of bondo...comes in a plastic swueeze tube like some other things. Great for finishing, and it is more flexible once cured than bondo
Soviet's Cupholder Teaser
This topic is closed.
looks like its gunna cost you more doing it the cheap way lolOriginally posted by ebelementsAlso, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
If you want to smooth it out a little. Paint it white. Use the black as a guide coat. Get yourself a nice little stick of wood like what you use to mix paint with and put some 80 grit sandpaper on it. It will take a while but when you have all the white spots gone you then apply some finishing putty. That will make it pretty smooth. I don't know if it will stay together as it was mentioned that the two materials are different. But you can make it look a little bit cleaner. A+ for effort for the first try. Make another one and try it out of real fiberglass, not bondo. Should be much better. I will give this a try, although mine will probably resemble lukes with enough practice.sigpic
Yeah, it was my first time. I like how it overall came out. I am sure I will do another one down the road when I find another e36 318 center console.Comment
damn that looks like ass.......oh well.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
Yeah I knew the type of comments I'd get when posting on r3v. But the ugly girl is funny a shit.Comment
