Just discovered that the domelights from the chevy silverado fit the slot where the check panel usually goes. A little bit of soldering, and you get 3 more lights when the doors open and maplights that are actually aimed in the right place. Wiring is easy, too: you can just tap into the wires running to the factory dome lights and run the wire under the headliner.
Pics:
Pics:
