I'm sure this has been beat to death but I can't find anything in the search so, what size (in mm) is best for a tall person, 6' 3", that allows leg room and still be able to see the dash clearly? Also is there a writeup somewhere for swapping airbag steering wheels? TIA
Steering wheel size
I am 6' and the wheel in this link is a 365mm that I have on my car. I had a MOMO that was 350mm and was really to small IMHO. With the MOMO I could not see the top parts of my gauges. The one I have now is borderline to small but it works. I would assume anything that is 365mm to 380mm you would be fine. Anything larger and it will look strange, anything smaller you will not like. In the link below it will take you to a link you should find everything you need to know on a airbag car steering wheel swap.
This post shows you where the torx screws are located to remove the airbag from the wheel
Just make sure before go disconnecting the airbag that you disconnect the battery to keep the airbag from possibly blowing up in your face... Also you will need to pull out the white plastic pin that has a spring around it in the lower left area of the column.Last edited by atomic; 03-08-2008, 07:15 AM.
Originally posted by BlackMagic View PostI think i saw that, but do you have a pic of it?
It is number 11 in the picture but it does not list what it is in the listing below the diagram.
