Recaro srd reps in need of good mounts
I got some Recaro Srd rep and the PO did a sh**t job on the mounts (well there is no actual mount) He drilled out all 4 original screw/bolt assembly at both sides and used some shave heads bolts with differnet size of washers as well as double nut (screw form the bottom) to hold the chairs.
I need a better solution for some decent mount. I plan to re-use these holes and repair as best as possible (i'm looking for a solid thick washer to slide it in between th emetals fof the cloor and underfloor to hace something solid once bolts put pressure on the metal)
Any ideas?
Any ideas?
