Check Panel no worky
  • Tavern Gnome
    • 2137
    Well since apparently nobody goes in the "general technical" area, I'll ask here. I bought my car a few days ago and the check panel did not work at all. I popped it off and it wasn't plugged in. I plugged it in and it still doesn't do anything. The only thing it does is give me a solid "CHECK" light on the gauge cluster. Any ideas? New check panel? Thanks,
    Ryan
    __________________
    1987 Toyota Landcruiser V8
  • Court M3
    • Jan 2004
    • 6713
    have you checked fuse? Forgot which one it is.
    Continuous For Sale Thread
    323i s50
    • Tavern Gnome
      • 2137
      Thats what I was wondering too. I was flipping through my Bentley looking for what fuse it may be. It seems that the check panel is tied in with a ton of stuff though. I would assume that if a fuse went out then I would have lost other stuff with it, like lights. I don't know. I'm going to poke around the fuse box and look for anything out. Thanks.
      __________________
      • VacMan
        • Apr 2007
        • 2405
        Do you have access to a known good one to try? Seems like that would be an easy way to find out the issue you're dealing with.
        Let me know if you end up needing one. I have a spare floating around I think I paid like $11 for at the yard.
        Tim
        • Tavern Gnome
          • 2137
          Tim
          Thanks Tim. I actually PMed Funkmasta about getting one this morning, haven't heard back yet. Thats probably the solution... I hope.
          __________________
          • Tavern Gnome
            • 2137
            Recap: replaced the check panel with a good used one from Funkmasta and the problem is solved.
            __________________
