This thread is really showing a lot of great DIY info. Keep it up Mr.Anderson.
MkII GTi Recaros in an E30
i am going to try and get some scrap aluminum this weekend and make new bases for my seats since they both have torn suspension until i can fix it right.
BTW they are more comfortable with the webbing supporting the foam than a solid piece of wood. if you use a construction sign, there is some flex to it so it is almost the same and it wont raise the seat bottom up to where you are not held in by the bolsters as wellseien Sie größer, als Sie erscheinen
Did most of the big shaping of the foam just a little while ago, even got a free brand new turkey carver from the mother in law! :D
Gonna have to add some more foam in a few places, and I took off a little bit too much in one spot, but that's the awesome thing about doing it this way, I can just stick on more if I mess it up. And I'll tell you, there's something very satisfying about doing this kind of thing yourself.
Originally posted by Mr. Anderson View PostI just realized that second pic looks like a big oatmeal cream pie.
By the way I got some dough so I can finally get that stupid piece from the UK...sorry Josh I'm not as talented, and I would never be happy with my finished product. And knowing me I'd accidentally torch my seat or something stupid.
All you need to know is that soon I will have my seats in!Reminiscing...
Besides, the guy at the upholstery shop told me the replacement bolsters are made from the exact same stuff I'm using, they're just injection molded instead of being shaped.
i did something with seat belt webbing (you can buy it a upholstery stores) for the drivers seat when i had them redone.
i was missing the "rods" that go on the sides and secure the netting to the frame. i worked pretty well, but it was a PAIN to make. the only bad part was i need to use some stronger rods on the sides because they keep coming loose.
it kind of ends up looking like a window net for you race car.
there is a LOT of sewing involved and you need a actual upholstery sewing machine to do it because the webbing is so thick.
can you understand what i did by my description?seien Sie größer, als Sie erscheinen
i wasn't being condescending by that BTW.
you really should try to sand or smooth out the foam before you apply the felt covering too. the smoother it is before, the smoother it will look with the cover on itseien Sie größer, als Sie erscheinen
Yeah, I got what you meant. Tricked325i said he would make me a pair of them, since I only have one of the original ones, I was going to send it to him to use as a template. But I don't have the cash right now to have them made. Then again, I'm not driving the car anymore this season, anyway. So maybe I'll just wait and do that.
And I am going to try and get the foam a little smoother before I put the felt on, I just don't have a DA, might have to see what my father in law has.
Originally posted by der affe View Postyou need a actual upholstery sewing machine to do it because the webbing is so thick.
that is what my friend who did the upholstery told me. you're his brother in law right?
hook him up! bust out your sewing machine and get some webbing.
i just went to the depot and bought steel rods to go through the sides of my "fix it". that should make it stay in place and i will be done with it.seien Sie größer, als Sie erscheinen
