Recaro: The Recaro Garage - All things Recaro
This is a sticky topic.
  • a2coupe2a
    • Aug 2007
    • 590
    #346
    Also keep in mind we do custom upholstery so each seat will eventually be full restored. We are in the middle of restoring the red ls's. As for those we are doing a diamond stitch insert and the slight bunching on the bolster was caused from me carrying them up the steps (carried them by the bolster) and i just didnt smooth it back out before i took the pics.
    ----- www.jjcustominterior.com -----
    We specialize in Recaro restoration!
    • Ray Smoodiver
      • Jun 2004
      • 8809
      #347
      Seek help!
      • a2coupe2a
        • Aug 2007
        • 590
        #348
        Originally posted by Ray Smoodiver
        Seek help!
        lol
        • a2coupe2a
          • Aug 2007
          • 590
          #349
          nobody else eh
          • dogsbark26
            • Nov 2008
            • 533
            #350
            The community needs more like you.
            • a2coupe2a
              • Aug 2007
              • 590
              #351
              :D The scary part is that this is only half of what i have
              • mach schnell
                • Apr 2008
                • 1059
                #352
                a2coupe2a - Sent you a PM last week.
                • frag
                  • 135
                  #353
                  got my first recaros!
                  oh, that's not me in the pic. :D i found these in a junk shop!
                  but how do i get the headrests off? want to clean them up properly!
                  http://arcautomotive.com.ph/
                  like us on facebook
                  Service • Detailing • Parts • Accessories
                  BMW Car Club of the Philippines
                  • a2coupe2a
                    • Aug 2007
                    • 590
                    #354
                    You want to remove the insert and you will see two metal clips holding the bars of the headrest in. Pull those out and the headrest will be freed
                    • M-technik-3
                      • 18946
                      #355
                      I have an identical just like that.
                      • AWDE30
                        • Jul 2006
                        • 762
                        #356
                        Originally posted by a2coupe2a
                        Got bored and banged this out tonight. Made it with a zipper so you could stuff it to your liking. Going to make some minor tweeks to the pattern but you get the idea..
                        We used a dark grey suede back.
                        Any luck having more of these made? I want a few for my new house.
                        • Eric
                          • 5141
                          #357
                          PM on the price of 4 8)
                          • frag
                            • 135
                            #358
                            a2coupe2a: thanks! but how do i remove the insert? i tried prying into it, but it seems like there's a cloth tab that's looped around a metal slot, and i don't see any way of removing it without cutting the tab.
                            like us on facebook
                            • a2coupe2a
                              • Aug 2007
                              • 590
                              #359
                              Read this, its not the exact same seat but it breaks down the same..
                              • a2coupe2a
                                • Aug 2007
                                • 590
                                #360
                                You pretty much want to lift up on the piece between the headrest and the insert. You will see the metal dowel sitting in the clips at the top of the insert. Push the dowel towards the back of the seat and up a little and it should come out of the clips. If it dosnt use a small flathead to slightly bend the clips upwards to allow more room for the dowel to come out.
                                Once you have the dowel completely freed you should be able to fold the insert down. It may be held in with hog rings in the center. You can clip them or just slightly bend the insert so it allows enough room to access the headrest clips but not soo much that you have to remove the rings.
                                If any of this dosnt make sense now it should once you start digging into it.
