Passenger side door pull problem.
  • SykoBMW
    • 1065
    Ok, I've tried google, but I can't seem to find any information on it. The passenger side interior door pull is extremely loose on the bottom and it cracked the plastic surround to it. Has anyone else experienced this, and if so, how do I fix this. I know I'll have to replace some things, I just don't know what :(
    The door can still be opened from the inside, but you must press hard on the bottom portion of the pull handle, while pulling it. Dunno.
  • John in VA
    • Aug 2007
    • 553
    These door pull units crack over time, and are cheap to buy & easy to replace, after removing the door panel. Same part is used in E28 5ers.
    The rectangular surround needs to come off first, as does the armrest.
    Most imports part places can get the interior handle unit & surround bezel/escutcheon, for example HERE. Search for "door handle."
