2dr vs 4dr carpet
  • iamsam
    • Jun 2008
    • 174
    2dr vs 4dr carpet
    OK i searched around a little and i couldn't find the answer to this:
    Will the carpet from a 4 door (87 325e) fit in a 2 door (318is)?
    I have access to this carpet for my 318 and i am not sure if it is worth tearing up carpets quite yet. Thanks for your help!!
  • atomic
    • Jun 2007
    • 5691
    www.realoem.com shows them to be the same part numbers for either a 2 or 4 door car. So I would assume it will work, but I have not messed with looking at the two to see if there is a difference between them...
    Maybe someone else can chime in if they have messed with doing this before
    • iamsam
      • Jun 2008
      • 174
      Actually that is a really good point. I didn't think to look it up on realoem.com, thanks!
      Oh and i also heartily agree to say "nope" to Obama. (your avatar)
      • mikegar
        • Aug 2005
        • 523
        what year is the 318? if they are both pre facelift they should fit, and if one is preface lift and the other is post face lift it might fit.
        Originally posted by Ferdinand
        I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
        DIVING BOARD DIVISION DIVISION IDIOT
        • Van Westervelt
          • 9365
          The only part that is different on the carpets is the back section directly under the rear seat. The 2 door has squared edges like the seats, and the 4 door has rounded corners. They will fit, just not exactly the same.
          • iamsam
            • Jun 2008
            • 174
            i am taking the carpet from an '87 325e and putting it in a '91 318is
            • iamsam
              • Jun 2008
              • 174
              awesome!! well i will give it a try and see what happens. When i do, i will post pics and stuff in my project thread (called "E30 Progress")
              • Chisum
                • Apr 2008
                • 229
                Wondered how this worked out for you. Are the seat belt holes in the same place????
                • iamsam
                  • Jun 2008
                  • 174
                  i never actually ended up doing the carpet swap. With a closer inspection i found out the carpet i was going to swap was really badly stained, and i would rather find a clean carpet.
                  • mikeedler
                    • 6707
                    I think the ends where the doors are are different(by the A/B/C pillars, and also where the seatbelts mount to the floors for 2 doors will have a hole.
                    also the iX has a different floor style as well as I am pretty sure but not 100% pos. that there is a difference with cars that have the climate-control A/C system.
                    I have also noticed that the floor on a 88 325e super eta U.S. specs has a different floor shape an a bar or 2 by the drivers footwell-- not sure how much of a difference that would make.
