I removed the part you sit on just fine, but the part of the seat the yuour back rests on wont budge... wtf? im new to e30s
How the HELL do I remove the rear seats?
It is bolted down.
There are 2 bolts,one on each side about 4 inches below the outside bottom corners of the seat.
Look around you will find them. Once you remove those bolts the seat just lifts up.
Hope this helps.
Andy-Andy
It should be a 13mm bolt holding a 1/2" piece of black metal coming out of the seat. Its tucked in the corner by the bottom of the seat back pretty good. There is also sometimes a piece of vinyl covering them, so you might have to push that over to see the bolts.sigpicComment
correct but 10 not 13 thoComment
[quote=E30 Groupie;1297273]Touche. I just took mine out and rarely ever put them back. Nobody is allowed in my backseat anyway.
[quote]
Well put. One of my friends was looking back there and noticed that I didn't have any seatbelts. Apparently I forgot to pull them out last time I re-installed the rear seat....a year ago. ;)Comment
