Sport Seat help!
  • elsabor67
    • Jan 2008
    • 837
    Sport Seat help!
    My bottom bracket (not the one that bolts to the floor) for the seat cushion broke on both sides in the middle. Does anyone know how to disassemble these seats that could shoot me some instructions. I looked around but couldn't find anything. Thanks for the help in advance.
    Nick
    How do I spell stress relief?:hitler:
    :!:Open Track Days!!!:!:
  • Julien
    • 7471
    there is a how-to out there somewhere.. I'll try to sum it up for you
    1.separate the top and the bottom part of the seat
    -2 small screws on the bottom of the rear cover, then pull up on the rear cover
    2. then take out the 2 larger screws that holds the top frame to the adjusting side brackets and pull the top portion off
    3. next take off both the plastic covers from the adjusting brackets and look at the center of the pivot, you will see an L shaped pin, pry it out (gently) and then take off the c clip
    4. also undo the 17mm bolt holding the adjusting brackets to the sliders
    5. at this moment the adjusting brakets can be slid off the bottom portion of the seat
    6. to take the sliders off from the bottom portion of the seat, look towards the front of the seat, you will see 2 pins holding them in, pull them out
    7. once all the adjusting junk is out of the way, take out the copper cllips holding the leather in to whatever side you need to access
    8. Pull off leather and weld frame.
    that was really vague, feel free to PM for more specific instructions, or meet me a the ring in april and i'll do it for you for a beer.
    cheers,
    Julien
    Build Threads:
    • boomer
      • 3019
      Hope these help.
      4 Steps for seat separation:
      remove the 2 screws on seatback
      unhook cable using a flathead screwdriver
      pry white tab upwards using same screwdriver
      pull seatback upwards away from seat bottom
      http://www.arghon.com/
      • elsabor67
        • Jan 2008
        • 837
        cheers,
        Julien
        Let me know when you come up here in April and i'll defiently meet you up there. Don't worry about the seat part.
        Thanks for the help guys. I'll be tackling it this weekend and keep you guys posted.
        • td325ic
          • Feb 2006
          • 788
          PM me your email address and I'll forward you some guides on how to take apart sport seats
          • StrokedSix
            • Jul 2006
            • 318
            this might help....
            • elsabor67
              • Jan 2008
              • 837
              Originally posted by StrokedSix
              I wish I would have seen this before I went head first into it. Took me a while but as you can see..............
              Completley broken off. the other side was on it's last leg:(
              It was easier than I thought. To all, thanks for your help and advice. I really appreciate it.
              Nick
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                Fuck yeah, thank you!
                Andy
                EDIT:Just saved me from needing my flame suit.
                -Andy
                • Cha Ching
                  • 1668
                  Houston, we have a problem...:eeek:
                  • norcalE30
                    • Dec 2008
                    • 932
                    hit a lot of jumps lately?
                    Originally posted by kronus
                    pff, all of you are slow as hell anyway. Eta > all
