Window problem
  • andrewc53
    • Nov 2008
    • 41
    Window problem
    I have 1 90 325i. My passinger window will go up and down but you need to work the switch quite a bit to get it up and down. Like dead spots in the switch. pushin down and up and it starts working. Is it the motor or the switch? Thanks A Curtis
  • thereisnoyun
    • Feb 2007
    • 2301
    switch. The contact points on teh switch must have corroded/burn off, since its a eletrical contact it will burn a hole on the contact through time. Opening it up you can fix it to work, but I would just get another one that works since they arent exactly a high demand item. .
    • andrewc53
      • Nov 2008
      • 41
      Thanks for the info. I am getting a couple new switches as they are cheep like you said . Just needed to know if thart was my problem. a Curtis
