Can power vaders fit in an e30
  • chrisesteschiro
    • 361
    Are they wider? Ive heard it wont work but why?
    Thanks
  • e30nub
    • Jun 2008
    • 1741
    Dude, if you looked a couple threads up at a sticky, you can see a HOW TO INSTALL VADER SEATS.
    For your laziness:http://r3vlimited.com/board/showthread.php?t=122849
    -Pierre
    1987 535is
    1988 325is
    • chrisesteschiro
      • 361
      I have already read that I wanted to know if power Vaders would fit? (Are they wider than regular vaders? Everyone ive seen uses manual ones. Thanks though.............
      • atomic
        • Jun 2007
        • 5691
        I think the power vaders are the same size as the manual ones. That being said it shouldn't be a problem making them fit along with some simple wiring. Use the link above to get your diy things to do....
        • chrisesteschiro
          • 361
          Question answered
          Thanks
          • Cha Ching
            • 1668
            Originally posted by chrisesteschiro
            Question answered
            Thanks
            Did I miss it? What was the answer? It seemed kinda vague to me...
            • bejbis
              • Dec 2008
              • 596
              i have power e36 m3 seats,not vaders, the bases are too wide to fit in the channel between the tunnel and the outside rail under the door. i would assume that the power vaders have the same base.
              -Dan
              • jconnorstefka
                • Jul 2008
                • 30
                I have installed manual and power vader seats in my e30. After measuring they have the same base dimensions.
                The power seat fit fine and is extremely easy to wire in for power.
                • Uber E30
                  • 1409
                  wtf happened to the sticky? Damnit i just picked some vaders up!
                  -Alex
                  • motorsports_3
                    • Mar 2007
                    • 1058
                    So since the sticky is gone, does anyone else have another link? TIA
                    • Rob
                      • 8166
                      Vader DIY: http://r3vlimited.com/board/showthread.php?t=128505
                      Its in the DIY forum...
                      BEERTECH
                      • motorsports_3
                        • Mar 2007
                        • 1058
                        I saw that thread, I am actually making those brackets. I am curious to see how to wire them up, I can't find a thread which goes into any detail.
                        • dinanm3atl
                          • Feb 2007
                          • 7305
                          From what I understand, and I could go look at the 328iC if someone really wants, there is a SINGLE 2 wire plug going to the vehicle. Power and Ground. The physical 'wiring' is built into the seat. All the seats need is 12v.
                          "Best" way to do it? Run a wire from the battery and build a 'new' harness with a BMW plug. That way you can easily unplug/plug the seat if/when you need to remove it.
                          The seats are the same. The physical seat themselves. Difference lies in the actual seat brackets but the 'bolt pattern' is the same.
                          • motorsports_3
                            • Mar 2007
                            • 1058
                            Sounds good, I wasn't sure if there was a two wire or multiple wire connector. Knowing that it is two, I could easily figure it out. Thank you
