Has anyone added any tasteful interior lighting solutions to the front and rear footwells? I was thinking about adding some lighting under the dash and somewhere in the rear seating area, using e30 fixtures. I have a lone interior light above the mirror in the cabrio.
Footwell Lighting Mod?
Where were you thinking of mounting them? Bottom of knee bolster and behind the glovebox?
Vert domelights would be perfect.
Wiring them would be easy once you figured out where the wiring is for the lights already there. Have a diagram?
I don't think rears are necessary, but if you want to, go for it.turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.
Originally posted by txleadfoot View PostThanks for the quick reply. I'm not interested in mood lighting, but instead "door open" activated lighting.
Get a few trunk lights from the junkyard. The forward center console has two 'arms' that extend to the front of the car. You can cut holes in that to match the size of the lights, and if you do it right, they will snap right in. The wiring is easy because it is all right there behind the kick panels.
