Carpet in Folding Top Compartment
  • txleadfoot
    • Apr 2006
    • 208
    Did BMW install carpet in the folding top compartment like this?
    The carpet has some nasty adhesive on the loop side of the carpet. The adhesive is ruining the plastic rear window when the top is stowed.
    I can't find this carpet strip for the life of me on realoem.com.
  • ezrez
    • 328
    I don't have that carpet on my vert...
    Current:
    92 325ic Mtech 770
    99’ 528it
    Past:
    02’ 325it - 88' 735i - 88' 325ic - 89' 325is - 85' 325e
    90' 535i - 95' 530i - 03' 530i - 88' 325ic
    • thereisnoyun
      • Feb 2007
      • 2301
      carpet is suppose to be there, I have it on mine. It prevent metal rubbing against the fabric and the window.
      • Stevie30
        • Apr 2007
        • 1534
        Both my '89 and '91 have it. It appears to be factory installed.
        1991 325ic and 1991 318is
        • 87Blue325iC
          • Apr 2006
          • 1111
          I have it
          Aaron
          • isamemon
            • Jan 2009
            • 257
            no fair mine does not ......91 318ic
            • AndrewBird
              The Mad Scientist
              • 11898
              It's a 318. It was left out to save weight. ;)
              • straight6pwr
                • Sep 2004
                • 3450
                use some goo-gone or goof-off or something and try and rub the troublesome adhesive away. if that fails maybe some black duct tape over the trouble area?
                • Fidhle007
                  I can fly, motherfucker
                  • Oct 2005
                  • 7209
                  Yes.
                  '89 325is S50 Track Montser
                  '04 X5 Daily/Tow Vehicle
                  http://www.avarestoration.com
                  http://www.myspace.com/brendanfiddle
                  Click here if you want to be my zombie slave...
                  http://www.youtube.com/user/Fidhle007
                  • txleadfoot
                    • Apr 2006
                    • 208
                    Don't use goof off on soft plastic.
                    Goof off damages the plastic window. Here's how I know:
                    My son attempted to remove a sticker from his iPod with Goof off and it damaged that plastic as well.
                    Since then I've gotten better advice from Larry Reynolds: Repeatedly dab P21S Total Auto Wash and blot until the adhesive is gone (no rubbing) with a microfiber cloth and follow up with Meguiar's Plastic Polish 10, 18, 17 (in that order) to get rid of the haze.
                    Still looking for a part number for the carpet! Anyone?
                    • straight6pwr
                      • Sep 2004
                      • 3450
                      i wasnt suggesting using it on the window. isnt the adhesive on the carpet area? thats what i meant. id hesitate putting soap on convertible window plastic, lol.
                      • txleadfoot
                        • Apr 2006
                        • 208
                        I thought about trying to get the adhesive off the loop side of the carpet, but I think it would be a futile attempt. Hey thanks for the reply.
                        • Cobra Jet
                          • Apr 2008
                          • 278
                          Just an FYI - the gray carpet BMW used is pretty similar to the gray carpet used by Car Audio stores for covering speaker boxes - and another FYI - Pep Boys used to sell the same gray carpet in I think what was a 10ft roll...
                          You can strip off the old factory carpet from your vert's well, clean up any residual remnants w/ goo off or other product, dry - then use the old carpet as a template to cut from the new carpet you decide to purchase... Use the 3M "90" spray adhesive (which can be found at your local Home Depot, Lowes, WalMart or mom-pop hardware store), spray the well where the carpet will go and also spray the back of the new carpet. Lay the carpet down, press it firmly all over and let dry before using the well for top storage...
                          Like I said, that carpet is not "special" by any means and you could essentially replace it with the same type of product OR even replace it with something that is better (softer)...
                          • NC325iC
                            • Mar 2004
                            • 6565
                            tengo
                            • dannyg
                              • Mar 2007
                              • 1553
                              Any body need this? Just took one from my parts car, good shape.
                              I just am an OEM parts whore so everything has to be oem for me!
                              1993 325ic Schwarz/Natur
                              1991 318is Black/Black - Slicktop - Project s52
                              1989 Alpine White/Black M3 S52
                              1988 Henna/Pearl M3 <3
