Under steering wheel/kick panel fastener
  • ethirtysix36
    • Feb 2013
    • 125
    I am looking for the fastener that goes under the steering column that holds the kick panel up. The first attached image will show the opening that I am referring to.
    The second attached image is a screen grab of the RealOEM page that should so what this fastener is. However, this item is removed from the listing. I believe it to be 26-27-28 on the diagram.
    Does anyone know which fastener this is?
  • roguetoaster
    Biggus Tippus
    • 7830
    Your pics are broken, but if you mean the one that clips on to the column and then has the panel slide in: 51451906532
