US Ellipsoids Installed; Lighting Issues
  • ZJP
    • Dec 2008
    • 52
    When the low beams are on and I flick my high beams, both low beams turn off and only my driver side high beam turns on.
    Any ideas as to why this is happening?
    WTB: '89-'91 5spd 318is/325is in Tri State area.
  • atomic
    • Jun 2007
    • 5691
    Unless you have done the relay jumper, then that is normal with how US lipsoids work and only one high beam is likely because the nonworking one has a blown bulb...
    • ZJP
      • Dec 2008
      • 52
      Oh I see. I was under the impression that the high beams would light up along with the low beams. I never heard of one without the other.
      • lov-e30
        • 16548
        Originally posted by atomic
        unless you have done the relay jumper, then that is normal with how us lipsoids work and only one high beam is likely because the nonworking one has a blown bulb...
        +1 ;)
        @IRON-E30 aka Edwin:D
        • coolasacuc
          • 383
          totally normal except you have a high beam out
