Euro elipsoid connectors
  • brodee
    • Jan 2004
    • 2914
    Where can I find the connectors for the euro elipsoids? I bought some and I'm missing the high beam connector on the passenger side.
    Also I thought these were a plug and play swap for us elipsoids. Was I confused on this? Mine have a different connector than the euros.
    "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
    1988 M3 - Track Rat
    1989 325iC M50 Vert
    1989 325i Coupe
    1991 318is
    1995 318ti Club Sport
    2006 330i e90
    2008 Tundra Crewmax
  • kencopperwheat
    King of Kegstands
    • 14396
    The US ellips use completely different connectors than the european ones. I'd talk to Greg and see if he can get you a used one for that passenger high beam.
    Originally posted by Gruelius
    • brodee
      • Jan 2004
      • 2914
      Thanks Ken. Not sure why I was thinking they were the same thing. Is it pretty straight forward as to which wire splices to which?
      1988 M3 - Track Rat
      1989 325iC M50 Vert
      1989 325i Coupe
      1991 318is
      2006 330i e90
      2008 Tundra Crewmax
      • kencopperwheat
        King of Kegstands
        • 14396
        If I remember correctly, I think the color should match up.
        • brodee
          • Jan 2004
          • 2914
          Thanks again.
          1988 M3 - Track Rat
          1989 325iC M50 Vert
          1989 325i Coupe
          1991 318is
          2006 330i e90
          2008 Tundra Crewmax
          • Ryan Stewart
            I Love Miatas
            • 8978
            European ellipsoid wiring connector from the wiring harness?
            Build your own from new parts from the dealer:
            The pins (need two per lense) 61-13-0-007-445
            Housing the pins clip into 61-13-1-378-417
            That info thanks to http://e30m3therealm3.com/
            If you want low beam connectors too check with Mike, he stocks the hardware kits for installing the sets he sells.
            Im now E30less.
            • brodee
              • Jan 2004
              • 2914
              Thanks Ryan, I may just run up to the dealer tomorrow and try to grab the parts.
              1988 M3 - Track Rat
              1989 325iC M50 Vert
              1989 325i Coupe
              1991 318is
              2006 330i e90
              2008 Tundra Crewmax
