Well once i got the car my head lights where messed up and here are is the problem. My pull switch in the first out position only turns on my corner and interior lights on. I pull it all the way our and all the headlights turn on Short and High! I also have to push the light switch on the steering column to the forward position to make it work and my high beam light turns on! Well i checked the Relays and fuses (replaced both) and i also replaced the pull switch and nothing my damn short beams wont turn on!!! help please!!!
This might help a little better
all the way in = all lights OFF WORKS FINE
1 click out = parking lights on WORKS FINE
all the way out = all lights (parking lights are still on) on but Low beams dont!!
BUT when i push the steering column switch foward all lights turn on High's and Lows Any Ideas ?
I hate this i replaced my bulbs and nothing!!!!!!!!!!!!!!!!
Well i checked my wires with the light check thing at my internship. My fuses are getting power and my switch is also here are the wires that make the tester turn on, GW/BW/WY/WG/WR. Then these don't YG/BB/B/BW, i don't have the diagram for the wiring on the switch so dont know which one works. Also when i tested the headlight i was getting power to the high beam when on, but when i turned it to low beam mode nothing, no power
I also checked the wiring book, and well i dont know lol
