As some may know, I bought new fog lenses. Well, my yellow Lamin-X came in yesterday and I am wondering the best way to apply it? Should I just do the front of the lens or do around the edges too? If I just do the front, will it look alright once they're on the car? I don't want the film to end up looking like shit. Anyone who's installed Lamin-X, tell em what to do!
Installing Lamin-X
Installing Lamin-X
Tags: None -
So just go up to the edge. If I recall [car is not ehre right now] they sit flush enough with the valance that it should be fine, right?Comment
Yeah, I'd just go up to the edge.Originally posted by MR 325So just go up to the edge. If I recall [car is not ehre right now] they sit flush enough with the valance that it should be fine, right?Originally posted by Grueliusand i do not know what bugg brakes are.Comment
I have them on my smoked ellipsoids. Wet them and the glass before you put them on, that will make it easier to smooth the bubbles out of them. There should be instructions that came with it. There will be some small air bubbles that you will not be able to get out, but when the car sits in the sun or lights are on for a while, the material will relax and the bubbles will disappear. I can't even tell there's anything on the lenses now.-Brandon
'86 325es S50
'12 VW GTI Autobahn DSG
'03 540i M-Sport (sold)
'08 Jeep SRT-8 (sold)
For sale:
S50 TMS chip for SchricksComment
ditto^^Originally posted by Beej '86 325esI have them on my smoked ellipsoids. Wet them and the glass before you put them on, that will make it easier to smooth the bubbles out of them. There should be instructions that came with it. There will be some small air bubbles that you will not be able to get out, but when the car sits in the sun or lights are on for a while, the material will relax and the bubbles will disappear. I can't even tell there's anything on the lenses now.Dan
wet them & the glass down with diluted IPA. if you can, take the fogs off the car. Also, if you can heat them up with a hairdryer for a couple minutes it will help, too.My mountains are better than yours.Comment
Ok, I got the Lamin-X on the lenses and I removed the fogs out of the car and cleared out all the old glass in them. Tomorrow I will install the new lenses hopefully. Pics may be coming. Oh ya, and I will do the hair dryer thing to help stick the Lamin-X to the lenses.Comment
clean those new acrylic lenses thoroughly with IPA (don't let it sit, wipe on wipe off, wax on wax off, miyagi says).My mountains are better than yours.Comment
razor blade the glass, then rub it clean with alcohol. then start from one side of the galss and apply it across using the plastic blade they give you. push it on from one side to the other to avoid bubbles. you can try to push it around the edges, but it wont bend to much.
negatory if you're doing this on acrylic lenses. be very cautious using a razor.Originally posted by shaherazor blade the glass, then rub it clean with alcohol. then start from one side of the galss and apply it across using the plastic blade they give you. push it on from one side to the other to avoid bubbles. you can try to push it around the edges, but it wont bend to much.My mountains are better than yours.Comment
It's already on as said above, now I need to attach the lenses to the housings and install the fogs tomorrow.Comment
Here they are
