Will Any Sealed Beam Fit In Any Spot?
  • FrustratedMunky
    • Apr 2004
    • 360
    Hey guys,
    I tried searching but no luck.
    I'm going to get some BOSCH H4's with Osram Silverstars in in the next month and my driver side high beam sealed beam has a rock chip in it. Since I will be replacing the low's with the BOSCH H4's, will the low beam sealed beams that I take off be able to replace the high beam sealed beam with the rock chip in it? I haven't popped them off yet to check if the plugs or whatnot are the same, so I was wondering if any of you knew off the top of your heads.
    Thanks in advance.
    '91 E30 M42 DIAMANTSCHWARZ
  • M-technik-3
    • 18946
    The sealed beam mounting is differant from the Euro H1's and some of the Bosch H4's have the same mounting style.
    • UNHCLL
      • 8790
      a replacement sealed beam is like $3 at any auto parts store.
      buy a new one. buy 2.
      or buy h1's to replace them.
      Below the radar...
