Wires for elipsoid conversion?
  • Simon S
    • Oct 2004
    • 3758
    Converting from sealed beam to elipsoids..
    (i have most of the plug housings already)
    When I order the wires - should i be ordering "0,5-1,0 MM²" wires or "1,0-2,5 MM²" wires?.
    I did some researching and can't seem to determine difference and/or which ones are best-suited for headlights.
    Thanks for any help.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
  • whiltebeitel
    • Apr 2007
    • 2098
    I have the US ellipsoid pigtails, if you went them.
    '89 325i track sloot
    '01 530i daily
    -Enginerd
    • TexasTerp
      • Jan 2009
      • 3541
      Are you converting to US Ellips or Euro Smileys? They use different pigtails and wires.
      stephenbrody.com
      • stumble_t
        • Aug 2009
        • 759
        I used the thicker gauge wire for my Euro retrofit. Also I used diodes instead of re-wiring the fusebox.
        [IMG]http://www.r3vlimited.com/board/
        • Simon S
          • Oct 2004
          • 3758
          smileys
          While i've seen different articles on doing the conversion - don't recall seeing any one single place that provided all specific part numbers..
          site i was using for guidance
          Japandrew post which indicates (per part#) use of the 0,5-1,0 MM² wires
          Some of the hardware i've purchased so far
          Part #s for high & low beam plug housings:
          2) 61131378417 Plug housing, white
          2) 61131378419 Plug housing, yellow
          Part # for city light plug housing(s):
          2) 61131378401 Plug housing
          The wires I initally purchased were "0,5-1,0 MM²". I didn't know if that notation designated wire thickness or a different style of connector. Now that I look at them, the wires themselves look thin - like 22 gauge thin. Thinner than i'd like to use for headlights.
          I am going to guess that the "1,0-2,5 MM²" wire itself is more like 12-14 gauge - and the connectors are the same.
          If that is true, then the (1,0-2,5 MM²) I'll want to order are
          High & low beam "L-shaped" wires:
          8 ) 61130007446
          City light / "straight-end" wires:
          4) 61130007442
          • E30FourLife
            • Aug 2009
            • 217
            I'm doing a similar conversion (sorry not trying to thread jack)
            I bought euro ellipsoids non smiley just the low beams. Want to convert just my low beams to HIDs I already have the H1 HID kit.
            My issue is I already have Cibie headlights by Daniel Stern lighting installed in my car so the wiring is a little different than stock sealed beams, although the Cibie light use H1 bulbs. Wondering i someone could give me some help to the Euro light conversion and put in my HID kit with it.
            00 Audi S4 2.7tt 6MT
            02 Audi S6 Avant 4.2
            • stumble_t
              • Aug 2009
              • 759
              I would suggest using the thinner gauge for the city lights, they are 5w I believe. Maybe you could use the other thin wires for the ground side? Yes the mm# is the gauge thickness and has no bearing on the plug size.
              After you wire these you will need to decide what you want to do about the HI/LOW switching problem coming from sealed beams as well.
              This is the parts list I used.
              Plug Housing
              61131378418 (x2)
              Plug Terminal Yellow
              61131378419 (x2)
              Plug terminal white
              61131378417 (x2)
              Circular Connector 1,0-2,5 MM²
              61130007446 (x12)
              • robrez
                • Jul 2008
                • 3376
                Any updates on this part list. I need to order. Thanks
                January 2012 COTM
