Removing Ellipsoid Lens
  • Skafrog
    • 1730
    Alright, so I managed to crack the reflector in my Ellipsoid. How do I remove the lens from the rest of the Ellipsoid? I assume it involves sticking it in the oven, etc, but I would appriciate a step-by step so I dont completely lose my money on these.
    Also, if anyone has a spare US ellipsoid reflector they would like to sell, that would be fantastic.
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
  • BavarianBimmer
    • 951
    I like did, put them in the oven for +- 5 min and try to puill of the glass
    with patience it'll work great ;)
    I've changed an lens and it didn't crack at all
    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
    1997 E36 328iT
    1990 E30 325iT 24v SOLD
    1989 E30 325i 2.7i M-Technic II SOLD
    • jmalixi
      • Nov 2004
      • 12
      What did you use to glue the new lens on?
      • bimmerphile
        • 3495
        Silicone caulk.
        • mikeedler
          • 6707
          I cut off the plastic lip on the outer edge with a side snip(dykes)for the politically incorrect, heat them with a heat gun, and cut into it along the edge with a very sharp cutting blade. have done a bunch of them to make black elips. the brights are a litllele harder cause they have the metal housing, but its the same principle there to.
          • BavarianBimmer
            • 951
            Silicone caulk.
            yup and it didn't fall off yet ;)
            1997 E36 328iT
            • golde30
              • 11464
              ok, i got a Q, how do u remove the entire ellipsoid unit from the mounting bracket?? its starting to piss me off, i know its mounted by the adjusting screws, but how do i get those suckers off??? TIA
              IG: @Baye30
              • ejs999
                • Mar 2006
                • 70
                At what temperature did you set the oven to remove the lenses?
                Edit: Thanks for responding to my PM BavarianBimmer: for the archives
                couple of minutes at 180C or about 350F in a hot air oven
                apparently you have to be careful as to not damage the plastic housings doing this!
