i bought this car a few weeks ago and figured my foglights were blown but i found out they only come on when i turn on the high beams. how could this happen ? all the wiring looks normal. bad switch?
fog lights wont work
Originally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Tags: None -
any advice? anyone????? pleasssseeeeOriginally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away. -
The fogs on the e30 are not independent. You have to have the other lights on to have them on. Look up how to make them independent. I know there are a few write ups on here.Comment
the independent mod makes them come on only with the low beamsOriginally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
I'm not using it. Just something I stumbled on.Comment
so you check the two fuses in the back of the fuse box by the drivers fender.
Have you checked the bulbs? If the tips are broke they will look good but not work.
Next put a test light to the connections inside the foglights with the headlights on. Ground on the front subframe.
The solid piece is the ground and where the light plugs in is positive.
They will corrode, if corroded clean with electrical cleaner and put dielectric grease on connections.
Check the connection going into the fog lamp with a test light, do same as above.
There is a relay that also can go bad.
Get electrical manual here http://www.wedophones.com/BMWManualsLead.htm1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.Comment
hmm the fog lights work just not at the right times. i found out what it may be. at one point there were mice in my car. so who knows now. im just going to wire them independentOriginally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
[IMG]http://www.r3vlimited.com/board/
