Sidemarkers
    Sidemarkers
    NC apparently requires me to have my sidemarkers working now. I got some replacement parts from another r3v member, but I'm still having some issues. The front driver's parking light and sidemarker only work intermittently. The right signal does work, but it doesn't light up with the parking lights. The bulbs have all been recently replaced, so I'm kind of at a loss. Any ideas? I'm going to pull out a voltmeter tomorrow and test for power, although I don't see why it would get power but not illuminate.
    On an unrelated note, the brake light LED in the check panel is constantly on even though all the lights work. They're all silver-based bulbs. It's not a huge issue, but if anyone has an easy fix I'd appreciate it. Maybe it's time I just replace the panel with a big dome light.
    Check for the side markers and make sure the connections are on all the way. I had my right rear side marker go out and had good connection inside the piece on the marker turns out the wires leading to it broke off and were just sitting in place so now I have to get a new set of wires for the marker which wont be a big deal because my buddy has a bmw shop and I get full access to it whenever I need it. But definately try the connections first. As for the check panel I don't know what to tell you.
